Fuel injector problem
yo tony
Manning, SC
I have the dreaded stuck fuel injector. It has happened twice in 4 months but never lasts after I shut it down and restart. Question is should I just go ahead and replace it or try some injector cleaner first. Thanks in advance
Ideally it should be replaced, because next time it could be a major event. Yeah, you could try fuel system lubricants, but they are best implemented in a maintenance situation than in a case like this.
yo tony
Manning, SC
Good deal thanks a lot. I was hoping I could pull a code off my sct tuner to be able to tell which one it was but it isn't showing any codes. It can't be that hard to change.
cseverens
MA
#6 seems to be real popular. that is the one that failed on mine as well.
yo tony
Manning, SC
Ford dealer showed a misfire on 3. Fuel injector was not the problem supposedly. Got new plugs today will put em Saturday, hope that fixes it
This will give you the chance to see if that plug has any fuel smell + if there's any oil on the spark plug boot. Don't know what Torrie is recommending these days for spark plug gap, but 0.030 seems to work very well. Many have confirmed that the SP534's come gapped stock at 0.030, so you may get lucky and not have to change the gap at all! Use a feeler-type gauge to measure gap, don't use those round gauges.
And a tune will eat plugs faster than OEM tune, so be prepared for that down the road. 15K-20K max.
onespdfrk
wtf...
Bloomington, IN
Hopefully it's something simple like the plugs!
On the plug gap - I just changed mine last weekend. The new ones were all perfectly gapped at 0.035 (stock gap) & I had to take them down to 0.030.
I use wire gauges for measuring plug gap - As SHOdded said, don't use the round ones!
Pintony
40 miles N.E. of St; Louis
Wow... I'm confused!!! Round? Wire? Someone please clarify this spark gap lingo.
P.S. Sounds like a bad coil if temp. makes it come and go???
onespdfrk
wtf...
Bloomington, IN
This is a wire gauge, similar to the one I use:
https://store.snapon.com/Spark-Plug...aft-Motorcycle-and-Small-Engines-P635167.aspx
This is the dreaded round gauge :
http://www.westmarine.com/buy/champion-spark-plugs--spark-plug-gap-tool--425761
These are notoriously inaccurate and will easily brake the fragile electrode on the iridium plugs our cars use.
Pintony
Thank you onespdfrk!
I have the round kind but W/O the chrome plate. But the plugs I gap are bf42,
I have had the same plugs in my Pinto for 20 years. Clean, File, Re-gap, Repeat...
I guess that will have to be one more item I can add to my tune list...
