jcostantino
I decided not to bump the other brake proportioning valve topic because this one is different.
With that, how much movement should be expected in the pins on the brake load valve?
Should I be able to operate the flapper with my hand?
Also, what is the distance between the flapper to the valve body on the valve?
My pins appear to be frozen but they seem to be frozen with open fluid flow so it's not so bad. The gap from flapper to valve body is about 1/4" and I tried to push the pins down and they wouldn't move - didn't try to pull them out though.
Any words on when these replacement plugs will ever be made? I'd really like to get those for my brake flushing and braided hose installation. May as well do it all at once.
Jeff
Jeff
