Front Sway Bar Size
Angrymongoose
Omaha
Forgive me if this is listed somewhere obvious, but I can't find it. I have tried parts website and everywhere I look does not have the size listed.
Does anyone know the size of the front sway bar on these? Specifically a 17 PP. I have seen some posts that say the PP had a slightly smaller front one than the non pp.
I'm chasing down a front end clunk and was gonna get some universal bushings and brackets from energy suspension, but I need the exact size first. I have a caliper being delivered later this week so I can measure it myself, but if someone knows the size I can order them now instead of waiting to measure.
I'm sure it's cold up there but, if you want to be really sure, a quick check with a caliper/micrometer will tell you exactly what you have. Find a cheap harbor freight or equivalent and measure a straight area for tube diameter.
S l1600
Angrymongoose
Omaha
That's what Im going to do. I already have one on the way for another project, but shipping has been all over the place lately. It's not scheduled to get here till Wednesday now, and its too late to cancel the order.
So Ill measure it when it gets here, but if someone knew now then I could get bushings ordered now so that they might be here by next weekend.
Angrymongoose
Omaha
For the curious the front sway bar on a 2017 PP is 27 mm. I unfortunately originally measured it at a slight angle apparently and wound up with 28 mm so now I have some bushings to return.
Plus side, the bushings were not part of the problem anyway and after replacing both struts/mounts up front all is taken care of.
