Front sway bar bushings
Markus
Ottawa, Ontario, Canada
Is it possible to replace the front sway bar bushings without having to lower the rear of the subframe? Do I need to live the steering rack off the subframe? This is for a 95 ATX.
The passenger side mount would be much easier with the rear of the subframe lowered an inch or so. The driver side was possible without dropping the subframe on my car, but it would have been much less wrenching with a little more clearance.
Ishodu
I replaced both sides with out lowering the subframe. It was a pain but I did get it done. The flex head gear wrenches really helped out. And when I was done I installed new shorter bolts. The ones that were on there were about twice as long as they needed to be. This made it much easer to reinstall.
poffffd
