front sway bar bushing replacement
sho4life
midwest
i forgot to replace mine when the engine was out. how hard is it with the engine in?
jayro
Auburn, In
You would need to support the engine so you could drop the subframe enough to get at the bolts. Kind of a pain (depends on your def of pain). There may be another way to do it.......if there is Im sure someone will chime in.
Jeremy
jayro
Auburn, In
I thought you may not have too, but wouldnt dropping part of the subfram with the engine on it put alot of stress on the bolts? I would worry that one may give way which would make for a very bad day.
You don't need to support the engine, just lower it enough the get the bushing brackets off.
