Front sway bar assembly part numbers for 2015 pp/pi
JP Strunc
Nebraska
Im about to start upgrading my 2015 non pp sho’s suspension starting with the pp struts and then h and r springs. After that is done I will do the whiteline rear sway bar and then the pp/pi front sway bar. My issue is that I’m having a **** of a time trying to differentiate between the non pp and pp front sway bar. I saw somewhere online that they revised the 2016+ end links I believe. If anyone knows the part number for everything I am going to need to switch from my non pp setup to the pp setup ie bushings, end links, sway bar, and anything else I’m missing, that would be great.
Highway Star
Just installed the H & R springs in my PI and am very happy with the results. They are however quite a bit stiffer than even the PI springs, but it corners flat
hosbaldosho
