Front suspension
OSU 4 SHO
Westerville, OH
I just installed 24mm front, 26mm rear sway bars with new stock bushings and endlinks. I am getting a "clunk" or thud sound when I turn a corner or accelerate fast. I am pulling the wheels tomorrow to check it out, but just wondering if there is anything i can look at right away. I would imagine it is the endlinks, but thought i would post to make sure. thanks, aaron
When you have it in the air grab the sway bar and try to move it back and forth. Maybe the bushings aren't clamping it securely.
nc89sho
S13 Sellout
Clemmons NC
very likely one of the front endlinks is loose... when the car is jacked half way up it's easy to think they are tight and they aren't.. check them they will cause a nasty clunk.
OSU 4 SHO
Westerville, OH
I got it. the subframe bushings werent tight enough. tightened them and the noise is gone. Thanks alot Aaron!
