Front Motor Mount Question
SHOwener1986
Does the radiator need to come out to replace the front motor mount? Is there an easy way to remove this mount or is it difficult, like most things on this car? :bonk:
Rob94
Northbridge MA
It is easier to do the front motor mount if you drain the radiator and remove the lower hose. It's not necessary, but it makes things easier. Otherwise, it is rather straight forward. Took me about a half hour, but I had the benefit of a lift. If you are doing it on your back, I'd say an hour or so.
GoofSHO
HUGE Dreamer
Vegas
Rad, does not need to come out....Yes it's a PITA....
B
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
As mentioned, the front is very easy provided you remove the lower radiator hose.
If you think the front is a pain, try the rear :bonk:
Rob94
Northbridge MA
To be honest, I found the rear mount easier to replace than the front.
