BETTY DAVIS
Any lessons learned as to the procedure for removal and installation of this component; ie special tools, pit falls ?
BETTY DAVIS
BETTY DAVIS
You must be talking about the crankshaft gear, behind the crankshaft dampner. It doesn't just slide off, you'll need to use a puller to get it off. I had to go to the hardware store to buy some longer bolts to fit the puller I had, because the set that was included in it didn't have the right size bolts. The mid timing belt cover bolts fit the crank gear, but I found that they weren't long enough.BETTY DAVIS:
Is the Cranck Sprocket difficult to remove. Does this component slide off.
BETTY DAVIS
and they bend easily if your puller isnt on there straight.masho95:
BETTY DAVIS
