Greetings,
We have a 95 V6 3.2 SHO She is smoking like crazy! but not at the exhaust.
It seems that some fluid (oil or Steering fluid) is leaking onto the catalytic converter and thus burning on the hot cat. What was once an anoyance, now makes the car not driveable (can't see).
The leak(s) must be small as she is rarely low on fluids.
So, to all you more experienced, please let me know where to start to find and fix this leak.
I gather from reading a post in the "How Do I" section that I need to pull the intake manifold (or at least the outer rails0 to get the the valve cover gaskets?
Any other ideas as to where to look?
BTW I flushed the radiator the other day. In the process letting the car run at idle for about 15 min the smoke diminished then stopped. A 10 min drive and it all came back.
Thanks
Kirk
Thanks
Kirk
