Fender Flares ... BIGGER!
30footSHO
In da mountains
Boise, ID
Boy, that took about an hour just to read through the last five pages. Can't wait to see the finished product. My hat's off to you---even the gas door looks good! I think you'll be well-received at car shows, and the detail and abundance of pics on this thread is unmatched. Excellent work!
flosho
Shooting Flames
wisconsin
PROPHET said:
Looking grand. :salute:
Prophet, just noticed those rims, its weird not seeing the white sho w/o the pure white slicers. ;) Looks good though.
SHOWYA. :thumb:
SHOWYA
TurboSHO Member
Houston, TX
Thanks but two words come to mind .... carpeltunnel! :) or is that one? :shrug:
SHOWYA
TurboSHO Member
Houston, TX
nc89sho said:
so any updates?? i want to see more pictures. :****:
Sorry fellas but i been hacking away at the audi fuel door. Trying to get a better fit. I had made mounting braket out of sheet metal but it was to thin for it. So i had to remake that out of a much thicker piece which has taken me a while because its that much thicker. Well the actual car is getting wetsanded to reapply another coat of base then it will be painted.
I decided not to do the moonroof on the car. Thanks for all the input on this one! :thumb:
Geek SHO
SHO Addict
Rohnert Park, CA
You certainly know how to build up our anticipation. I'm about to die right now from being left at such a "cliffhanger". :)
Looks like it's coming together nicely. Simply fantastic.
PS: For anyone curious about custom HIDs, I have a little writeup on mine at my Cardomain site:
Clicky!
SHOWYA
TurboSHO Member
Houston, TX
Nope not done yet ... since i had told them to stop on the work because i was considering installing a sun roof so they pretty much left it alone till i made up my mind. Anyway. I spent 3 hrs today cutting and grinding at the fuel door area and finaly got it done with the stock door handle release being functional. Ill talke pictures tomorrow. It looks really good. but if i take the whole assembly off looks like somebody chewed on the fuel door opening.
They started on it again today, since they had to reschedule the work to include my car. So the engine compartment is being bolted back together, and the car is getting wetsanded to reapply the base again to then paint.
Total time without SHO ... 8 months and counting.... :eek:
n8rsk8r
Hey Where's my post?
Olathe, Kansas
:cry: I am there with you bro :cry: I won't have the car you will, but I am there with you, I took my sho out last night to see if I could get it otta 1st, and no luck, the atx is not havin it. I found a receipt in there from my bank from 2/24/04, that was during the one week I had the sho fully functional this year. :cry: I know your pain brother!
SHOWYA
TurboSHO Member
Houston, TX
Geek SHO said:
That's what backup SHOs are for!
LOL ... cant afford one at the moment as you may have seen in this thread!
Currently looking at a (winter beater) 91 civic HB 5 speed for 1K. I think i might buy it.
Porkchop
The Black Sheep
Virginia
This has to be the first car forum soap opera in history ... this thread has over 12,300 views and counting. Talk about knowing the pulse of the SHO community!!
platoribs
Live to Drive
Plat0ribs House of SHO,il
OK Ramone, you promised updated pictures today... tap, tap, tap, (drumming fingers on table) where are they? Gots to get my SHOya fix before I go home. Oh well, your probably gonna post em this evening after work. See ya tomorrow, same SHO channel, same SHO topic.
cmichaelo
Gee, Ollie!
New York
Just wondering about how you're planning to push your wheels out to fill the fender and are gotta assume that you'll be either buying custom wheels if you wanna go 18" or greater. Cause the SHOs bolt pattern is rare and I assume you would want to reduce the offset about 40mm or so.
I have a 94MTX on which I have totally removed the rear fender lip. I then had 2 20mm spacers custom made to push the wheels out as much as possible without rubbing.
In the process I had the remove part of the rear side molding (door section) as this was where the tires were rubbing against after I installed the 20mm spacers.
I run 18x8.5" rims with 235/40-18 tires. Car is lowered ~1" in the rear.
The main problem I had pushing the wheels out was actually with the wheel studs. The stockers were just too short. I ended up punching the stock studs out and expanding the holes in the hub to fit longer studs.
Unfortunately, longer studs were not available with the same 12x1.5 stock thread. So now I'm using 1/2"x20 studs in the rear.
As you can imagine, since the front studs are still 12x1.5, noone else but me will EVER change wheels on this car.
Michael
RI-SHO
B to the BANNED
Pawt., RI
You had that much trouble fitting 18x8.5? What offset were they?
I had 40mm offset 18x8 rims on my last SHO with 235/40/18 tires with no clearence problems dropped 1.50" rear and 2.75" front, here:
To have his rims stick out further to match to the new fender he'll need something wide like 9"+ rims with 35mm or spacers.
