Fan Help
92inPA
s.e. PA
By "put it into test mode" I assume you grounded pin #14. That would trigger the fan relay thus putting power to the fan. If both the CCRM and fan are good, most likely the signal circuit is malfunctioning. Check the wiring from the CCRM pin #14 to the temperature sending unit for damage. If that all tests good, the sending unit would be the next suspect.
tdaily2
South Carolina
when i put into test mode i was using the ob1 port and then turning the key to run and i would get the fuel pump and fan to start up im not getting a fan when the car is running all the info you can give me is a big help thank you:thankyou:
