Exhaust valve failure???
AREA 91
PA SHO SHOP
Area 91
Have any of you guys had any exhaust valves fail??? I was wondering how durable the 3.0 valves are. Mine seem to have "machined circles" in the face of the valve. Is this normal??? Are my valves going to fail??? Any advice is appreciated... rant
twr
whoohoo
half-way there, I think.
That sounds normal to me. It is very rare that valves are a problem on any motor. Unless the engine was run very lean which can burn the exhaust valves or warp the intake valves.
Do you have a picture of the valve that you are worried about??
<small>[ April 30, 2003, 04:27 PM: Message edited by: twrsho ]</small>
No valve problems after 272,700 miles (knocking on wood). Compression numbers are still within allowed range for new engines.
AREA 91
PA SHO SHOP
Area 91
Thanks for the input guys. I might be over reacting because I run my SHO like a ***** ape... :p
SilverSHO
cartersville
witsimpala:
In that case, you'd better worry more about your differential and engine mounts than your valves.
AREA 91
PA SHO SHOP
Area 91
New motor mounts on the list, tranny #2 going in.....damn those diff pins.... headbang
