I came up with a replacement for the discontinued engine torque damper. found a 6" universal elastic damper on ebay for $33 on ebay. it has a fixed bearing on one end and an adjustabe lrod end bearing on the other. to make it work i removed the adjustable end and installed a 4" garde 8 10mm coarse thread bolt in its place, used the included lock nut to fix the top of the bolt tight to the upper mount and reused the top mount upper and lower rubbers and washers on the 4" bolt. the bottom rod end is thinner so i had to use 2 washers on each side of the bearing to fill the gap on the bottom bolts unthreaded porton, but the bottom bolt fits the bearing tight. so far its working great( alot tighter) If any one wants to check out the damper the sellers name on ebay is "boostmasters" and the current auction # is 170635067610. im picking up 2 more for the other mounts and will post pics of the install soon!
