1991 SHO, EGR removed / PCM swap. New intake runner couplers, replaced entire set of intake gaskets... secondaries, the whole nine yards. New plugs, wires, coil.
Runs decent, no bottom end power in 1st gear, seems like secondaries don't open (can't hear of feel them open). Still need to change the O2 sensors (have them, going in tonight.)
After 10 minutes of running, CEL comes on. Codes are 81 (MAP Sensor?) and 41 (O2 sensor?) Knew the car was running lean, so the O@'s will be swapped tonight. MAP sensor is odd. Looked at mine (if I'm looking at the right component, firewall, just below the cowl vent - passenger wiper area) and it looks like there's supposed to be a vacuum line attached to the MAP sensor... mine just has a gray plastic cap that has a hole in it that does apparently nothing. I have no idea what vacuum line goes to it at all.
Any ideas????
-Mike
Any ideas????
-Mike
