Dumb Motor Mount question
94FordMan
OKC, OK
This may sound kind of dumb, but here goes... I did the Shotimes procedure for checking broken motor mounts, and my front MM was broken. I ordered the part from O'Reily Auto Parts, and it came in today. They gave me the mount, since I have never seen it, I'm not sure if it is the right one :confused: . Also the mount looked USED!! :mad: , so my dad and I went back up there, and he said to try it, and if it doesn't work we will get another. Here is a picture...
Just making sure it is the right one (wouldn't be surprised if they ordered the wrong one, as the guy I ordered from was deaf. :rolleyes: Thanks!
<small>[ September 06, 2002, 08:20 PM: Message edited by: 94FordMan ]</small>
SnickterP
Merrick, LI, NY
That is NOT what a front motor mount looks like! I have a question as well, my front motor mount seems to be constantly losing one of the top nuts that hold the bolt to the engine. its a sho nuit reinforced mount, so it doesnt seem to wanna break, but the dam thing keeps getting loose! its driving me insane. i put a new nut on it tonight and on the way fomr from my freinds it already seems to be loosening (IE jerky movement, motor moves excessively again on pass side). should it be locktighted? or does it maybe have to be tourqued? any help much appreciated
You must specify if you have a 3.0L or a 3.2L since the mounts are very different. I found the local auto supplies, including O'Reilly and AutoZone, to have the incorrect mounts listed for the SHO 3.0L.
LaTechSHO
Louisiana
I've done some research on this at work (o'reilly) and it is the mount manufacturer's fault on that... o'reilly, advance, and i think even autozone carry pioneer motor mounts...which are good quality mounts...but do a **** poor job of cataloging them..... does anyone have a good picture of the correct motormounts so i can see about finding the pioneer numbers for them... fyi.. in the pioneer book..there are about 8 different mounts that say SHO next to them... different years...so as i said... any good pictures...
Louis
ps. the one pictured above is the regular old 3.0l mount
94FordMan
OKC, OK
Thank you so much for your concern beer ... Since you work at O'Reily, how would I go about returning it? Just tell them it is the wrong one? and then give them the correct number (hopefully if you can get it). Once again thank you everybody!! thumbs_u Looks like I may not get this done this weekend after all. frown
RStalveyARFF
too many shos
Georgetown, MA
MTX mounts are ford only. I checked the entire anchor motor mount picture catalog (autozone and pep boys supplier), no dice. For ATX mounts, you can go through AZ, Napa, Advance, of whatever else is local. I'd spring for the sho nut reinforced, they're worth it.
LaTechSHO
Louisiana
just goto o'reilly and tell them its the wrong thing.... you want your money back.....
and i understand that the mounts are considered oem only... still....there have been many occasions when i have found aftermarket manufacturers make a part but don't list it properly... or even at all... if anyone has pictures it would be greatly appreciated.... and we don't carry anchor at o'reilly... so maybe a different brand.. a different chance
Louis
LaTechSHO
Louisiana
OK....as for the motormounts...i don't have pictures of the RIGHT ones...but after looking at the ones on my car (limited view without taking them off) and talking with the pioneer rep..... here is what i have come up with
tranny mount = pioneer # 621038 19.99
rear motor mount = 611173 79.99
front motor mount = 602791 - 18.99
those would be the correct part numbers... to the best of my knowledge... the tranny i'm 99% sure of.. the rear mount i'm about the same on... the front mount i haven't actually seen..only had description over the phone by the pioneer rep...and sounds good.... plus we went throught the listings and ford part #'s ... thats what i got.... if someone has valid pictures of correct ones..email me with them and i can make sure about it... but as i said... i'm pretty sure
Louis
93nighthawk
Mitchell, SD
That looks like my front motor mount (ATX), It does not take much for the paint to chip off, just shipping will do it.
lb-sho: Are those the part #'s for MTX or ATX? Sense SHO-nut does not make reinforced ATX mounts I would like to find a cheaper source than OEM. Anybody?
Eric
LaTechSHO
Louisiana
ok... for ATX motor mounts...have NO idea what they look like...however talking to the pioneer rep... these are the part numbers that should get you squared away
front - 601175 29.99
rear - 611177 49.99
tranny - 672717 -- special order..don't know price... will update monday night
Louis
RJ-92
Crappy NYS
94FordMan:
[QB]
[QB]
This MM pictured is the front mount off of a 3.2 ATX. They are quite different than the MTX mounts. The ATX mounts are suposed to hold up better. If your car is an MTX go the SHO NUT route, I got my rear mount from him, It is awesome. I will will also soon be replacing my SHO Shop reinforced front mount that failed after just 2 years. frown
