disabling/fixing alarm
rpishoman
Troy, NY
I'm looking for a way to turn my alarm off, so that I can avoid the engine ****. Reason being that when I had a new circuit wired to make my horn, fog lights, brake lights, and hi-beam flash work again, i have to press the 'un lock' button on my remote 10-30 times to make the alarm deactivate, even though the doors will unlock every time. Even using the keyless entry pad doesn't work, it just unlocks the doors like the remote. I was hoping there was a fuse i could pull or a wire i could disconnect, or even better a way to fix the alarm so that it works every time. Thanks
rpishoman
Troy, NY
Yes, they have a starter ****, which is why i needed to fix it, but what i ended up doing was taking the two wires that went to the override button, and splicing them together. Pretty much means i dont' have an alarm, but at least the car starts without 5 minutes of hassle with the remote now.
