93rev2sev
And the reason for the small hammer (versus jumper-wire) is . . . .
Saves you from upside levitation under the steering wheel; also it's 30 seconds as opposed to 10 minutes.
He took the guts from a 125 MPG blue one and put it in the case for a green one. The lens on the case is what determines the color. If you could find a big enough piece of rose colored plexiglass you could have a white digital cluster. If you want to go totally custom you could always use gauges from Dakota Digital. I have those in my 3 gage pod.Please elaborate!
Did you swap gauges between different year clusters? Between different application clusters? Or was it a Gen II cluster that you converted from blue-green, to green? Any other documentation?
Some of the clusters I have gotten have an 800 number to call for tech help. I have never called it though. AFAIK there is no such thing as a digital cluster troubleshooting guide. I also have never found any kind of self test routine for this cluster. I have not ever had to change anything on the fuel pump or float when doing a conversion. In fact a number of SHOs that have had poorly functioning fuel gages worked better after the swap. The Fuel Computer functions, on the other hand, use the Fuel Flow pin on the ECU for there signal. It is documented on the MTX pin out but I have never located it on the ATX SHO ECU. The 6600 RPM limit is hard coded into the cluster AFAIK. When you hit 6600 the Tach just jumps to full readout. I'm sure someone with the proper electronics knowledge (not me) could possible get into the RAM of the cluster and might be able to reprogram something. Also for your information; there are at least 4 different Taurus digital clusters of this style: Green with 85 MPH top speed, Blue with 85 MPH top speed, Blue with 125~ top speed, and Blue with Flex Fuel computer. There is a compatible cluster from the Windstars also but it's tach only goes to 6000 RPM.
In reference to the earlier-year digital clusters - I also found clusters in an LX for 86 and 87, the latter having a mosty complete dash, although the EATC looked pretty rough. Is this the same unit used in the 89-90 Gen I vehicles?
Anyone come across information on the AMP black 20-pin connector to the cluster?
I went through Mouser Electronics nearly 2000-page parts catalog without success. Currently searching online without success . . . .
:banghd:
But what would store the mileage-memory indefinitely in a salvage yard vehicle. At some point even an on-board battery source would draw-down. Does the odometer then go to zero?
Btw, what kind of digital camera did you use to take you images?
A couple q's for you in regards to installing the Digital dash
1st, The positive and Negative data, is there a reason to have that hooked up? or is there even anything in an X2J pcm to allow these to be hooked up?
2nd, the ground for the fuel sender, and the ground for the temp sensor, did you just use a common ground? or did you run a wire to each as a ground wire?
3rd, does the signal for the Speed sensor have to come right from the PCM? or can it come from the speed sensor itself?
I'm sure that I will have a few more as I get into this deeper, I have a 90 EVTM at my disposal, so I can look up anything else that i might need as it arises.
