Pull the codes, I know.... It's almost midnite, and I just drove 5 hours..
Well, stop and go.. LOL
Here it is, New fuel filter, changed TPS, coil, cleaned MAF, new O2's, good grounds. Bogs and dies, at low rpm's, mainly.
It is not using coolant. When it acts up, you can floor it, and it wont rev at all, you have to goose the pedal till it will rev..
Started randomly dieing at lights, or under 3,000rpm..
I have to feather the throttle until it quits bogging, then it revs, and I have to keep the revs up, or it will die.. Runs great on the freeway, no overheating. Check engine light is on.. unplugged the MAF, ran worse..
Unplugged the FPR vac. hose, no difference. unplugged the TPS, no difference. Changed TPS, no help.
I heard my exhaust "Boiling" long after It died on me... Maybe the cat is shot?
Sounded like a steam radiator.. haha.. SO, I changed the O2's... NO help..
Smelled some strong gas smells a couple times, it runs fine on the freeway, then just dies out, and coasts to a stop.. After a while it will start up, and will go anywhere from a block, to 100 miles before stalling/bogging/surging/dieing.
Usually at a light, or in traffic...
Drove it 172 miles one way, ran great.. On the way home, well, you know..
Ideas??
Pull codes..
check fuel pressure..
Ideas??
Pull codes..
