cRaZySHO.
Okay here's the deal, I had my TSW Revo's mounted with 245/45/ZR17 tires mounted today. The wheels have a 40mm offset. The tires rub in the rear, but not on the outer edge of the fender. I believe they are rubbing on the strut housing. It's been raining all day, so I haven't gotten outside to jack the car up, and look(with the Intrax's, they sit tight in the wheel wells!).
I have found a set of wheel spacers for a 5 lug set up from Jegs. If I use these, will they in turn make the outer edge of the tire rub the fender?
In my search I found that 40mm can hold a 235 tire no problem, but I don't see many people using 245's.
If I need to roll the fenders, I'm not worried. I just don't want the tires rubbing on the struts.
One more thing, if I were to use a 5/16" or a 7/32" spacer, will I need longer wheel studs?
And these wheels look sick painted in IS300 gunmetal with those meaty tires on them! And I can only get two fingers in between the front tire and the wheel well! Now that's snug! And in the rear, the tire sits up in the wheel well, no gap at all!
Thanx in advance!
Thanx in advance!
