So, as many of you know my ford has issues, it will bog down, loose huge amounts of power.
The last dealership that had it blamed the cats. and a bad turbo.
I want to preface this by saying at this point im over dealing with seller, the warranty people or ford, i simply want to get the car running. Im approaching this from a no warranty POV.
My father who also initially suspected the cats, pulled the exhaust apart. the DP cats were pristine, no clogging no discoloration. Not the issue. There was also no oil in the exhaust, and little oil in the IC. (likely what happens to all the Taurus's" however it was "repaired" the dealer was right so its not warrant able.
That said, gutting the slightly clogged rear cats did nothing to help. there is no flow stoppage in the IC.
My father also checked the wiring harness that the first dealer blamed and can find no exposed wires.
He was going to test the fuel pressure, but his kit will not interface so he must wait until he can use the scanner from his job.
Right now we have rulled exhaust out as a cause. We have also rulled the turbos and IC out. Both map sensors have been replaced.
My father suspects fueling, i suspect a sensor
id appreciate any thoughts.
Im getting to the point where im likely going to have to start throwing cash at it and seeing what works..
