Deer Hit
SHOTrio
Georgia
Need passenger side headlight housing, turn signal housing and parking lamp housing, (the little clear lens in center) for Gen II 1993 - One of five that I have owned)
zoomlater
Seattle, WA
Contact SV&HOdan
Is the header panel damaged, it tends to crack
zoomlater
Seattle, WA
Try and find an OEM one from a Sable or Sho, the after market ones are not that good
SHOTrio
Georgia
thanks already looked in my general local area but nothing left to pick from. Montana is a high deer hit area apparently.
Northeast87
Wareham
What are the 2 little light on either side of the grille? And where can I find them?. I don't know what they're called.
zoomlater
Seattle, WA
not sure what Ford officially called them, but they are referred commonly as fishtanks. you can send a message to SV&HOdan to see if he has any sitting around
Northeast87
Wareham
Thank you. I found the headlight assembly and they come all one piece but everywhere I look they're out of stock. Do you know of any place that sells only SHO parts?
zoomlater
Seattle, WA
Shosource has a lot of parts, but probably not head lights. You can ask them, but I would check with SV&HOdvan first
