Cylinder head bolt washers
tompumped
VT
I threw the old ones out like an idiot. If someone has a set let me know. I thought the bolts would come with them.
I guess I can use arp washers i'll just have to measure the cylinder head tomorrow, but if anyone has a set let me know.
tompumped
VT
I ordered arp washers I should've probably ordered the washers with the chamfered ID, but I just ordered 200-8747. The head bolts I purchased from them in the past for a SBC had a chamfered ID.
tompumped
VT
If these don't work i'll probably take you up on it. Thank You
tompumped
VT
Thank you. This was the third set of head bolts i've purchased you'd think I remembered they didn't come with washers.
I pulled my heads back off because there was five to ten percent leakdown. I didn't lap the old valves to the new heads. The leakage was so slight that if I didn't have tape on the exhaust ports i'd have never noticed and assumed it was the rings. The exhaust was the larger of the two but the intake leaked very slightly as well.
