Custom Sway Bars
SUPRSHO
Richmond, VA
I wanted share the information on the company that will fabricate sway bars to your desired diameter.
www.tlssteel.com
The prices drop greatly the larger the group buy.
Example: http://www.angelfire.com/biz/tlssteel/corollaprices.html
I checked with them they do not pattern for the taurus and will need a sample front and rear sway bar to make the pattern, after that armed with the pattern can make various diameters using that pattern.
I think I will settle on a 26mm front and 28 or 29mm rear with Koni and intrax :dribble:
Dan H
Seattle
I have 26 Front, 28 Rear, and the IPT coilovers, and the car is way to stiff for the street. I would however not mind running that combo with soft stock springs.
FWIW, Body roll is non-existant with that setup.
