ok i thought my crankshaft pos sensor was going out so i changed it. when i started the car it would run but after about 30 mins of driving the check engine light would come on and the tach would quit workinfg and it would run bad. if i turned the car off and restarted it the car was very hard to start and if it did the tach wouldnt work and it would run bad. so i got the sensor replaced and went to start it and it turns over and its getting fuel and spark and the timing is right i think buttttt........................................after trying to turn over for a while it backfires through the intake ..................is that timing i have the dimple on the cams at 12 oclock and the white mark on the crankshaft at 0deg on the the marks on the timing cover/???????????????? what the **** is goin on geez oh and i did gap the sensor .030 so what can the prob be??????????????????????????????? pls someone help me i cant miss any more work.............oh yeah when it did run right it ran like a beast so i dunno what it is very quick car
