Hi everyone.
I just purchased another SHO (had one back in 2001) - so I'm back on this great forum.
I'm trying to diagnose A/C problems.
To start out, I was unable to charge the system because the Compressor is not energizing. Even when the pressure switch is hotwired - no "click" on the clutch. The clutch is free and not seized.
I was told that the A/C was working when last parked (it's been grazing for 2 years).
Thanks in advance for your diagnosis.
Lyle
Lyle
) and MAX A/C then there is something wrong with either the EATC or the CCRM. If you are getting voltage there, then while it's energized hit the clutch (the part that isn't spinning) with a broom handle or other convenient pokey thing and see if that gets it to work. If it does, the clutch is gapped too far and will need re-shimming (there are thousands of posts on this). If THAT doesn't work, then the coil is fried (this is unusual) and will require replacement.
