Coil overs on 89 sho
NJshofear
Medford NJ
i know someone posted pics of the coilovers alone, here is a pic of my sho with the coilovers on.
and the front tire
Jeremy
Red 89 SHO
MODS:
-Upgraded brakes,
-17x7.5 Alesso Turbo(hyper black) wheels W/falken GRb fk451 tires (225/45/17)
-Custom bent single exhaust exiting under SHO on the back bumper
-Coilovers from IPT
-Pioneer head unit, with 2 Rockford Fosgate 12inch subs, and RF amp, Alpine amp.
-Two row copper radiator
Coming soon: SFC, LSD, forced induction (twin-turbo or a S/C)
AIM:Tiedie6683
noSHO
ohio is for hustlers
Woooow
. Looks great. That is one NICE red SHO too. How many miles are on that thing??
-Dave
green/black 92, mods
8359139 68b0 00C8006C
NJshofear
Medford NJ
Originally posted by noSHO:
Woooow
147xxx miles
Jeremy
Red 89 SHO
MODS:
-Upgraded brakes,
-Coilovers from IPT
AIM:Tiedie6683
yhardy1273
orlando,fl
NJSHOFEAR IS THAT WITH THE COILOVERS ALL THE WAY DOWN. ALSO HOW WAS THE RIDE AFTER THEY WHERE INSTALLED!
1993 SHO
5 SPD.
EIBACH SPRINGS
SUPERCHIP
FLOWMATERS
K&N CONE FILTER
18X 7.5 ALBA BLADES
225/40/18
AND A WHOLE LOTS MORE
1fastsho
Athens Ga
No they will go lower than that...I had mine lower for 1 day
It looked good but was too low for street IMHO.
Shawn Pasley
Innovative Performance Technologies
770-725-4631
www.iptech.tv
92 SHO red/grey
3.2L(bored) Lowered compression(9:1)
stageII cams, Ported/Polished heads,Ported/polished Intake manifold(runners, endtanks, and behind the throttle body), big bore butterflies,80mm maf, LPM,equal length Long Tube Headers and custom Y pipe, Dynomax cat-back, Koni/coil-over suspension, poly-bushings everywhere,26mm FRONT sway bar, 28mm REAR sway bar,rear strut tower brace, solid subframe bushings,subframe connectors, tubular aluminum adjustable rear control arms,shortened shifter,235/45/17 Toyo Proxes T1-S's on TSW VX-1's. 15 lbs of boost here I come!
SHO_POWER
Ontario, Canada
I wanna see some pics of it cranked right down as far as it will go.
NJshofear do you have any pics of the center exhaust??
'94 ATX
NJshofear
Medford NJ
yes i have a pic of the center exhaust but im in the middle of getting a new exhaust tip setup made. right now i just have a monza double outlet tip and it looks kinda weak. Ill see if i can dig up the pics for u.
Also the ride with them like that is very nice. A bit rough but like shawn says when u hit the turn at 60 you forget about the roughness. its not bad. Also i still need to trim the rear fenders so when i hit a big bump at speed, it occationally rubs.
Also the grill is getting replaced with a new one where just the sides are cut out.
Jeremy
Red 89 SHO
MODS:
-Upgraded brakes,
-Coilovers from IPT
AIM:Tiedie6683
