mikiedreb
Same codes, same circumstances.....now for the fourth time. I'll start the car up first thing in the morning, back out of the driveway, proceed up a slight grade and within a couple of blocks..the old CE light comes on. Throttle response is sluggish off idle, but seems to clean up as the rpms rise. Outside air temp 50 deg. Codes reset between occurances.
173: HEGO sensor indicates system rich (RH)
177: HEGO sensor indicates system rich (LH)
219: Spout default to 10 deg. BTDC/Spout cir. open
What's happening? I thought that these sensors were not operative until the car was warmed up, and in closed-loop mode. I'm wrong again?
Both sensors are less than 1K old, so I tend to believe what they are indicating. No intake leaks, recent plugs, wires etc. Spout connectors clean and ohmned. Recent 190lpm fuel pump & filter. Maf sensor cleaned, K&N filter clean. Every damn thing cleaned and re-connected
Help would be most appreciated.
Mike
92MTX
<small>[ April 09, 2003, 12:37 PM: Message edited by: mikiedreb ]</small>
Mike
92MTX
