Mikey
Think i got these right 176 is front bank lean and 452 is vehicle speed sensor. I have a catless Y and was told that it can cause the C\E light to come on because the o2's dont get hot enough.Both o2s are new also. Is there any truth to that and if so how do i remedy the problem. I also ended up damaging all four Vehicle speed sensors because they were so seized into their holes that the amount of force required to take the front two out that it cracked them, and i just cut the back ones out because i had to use my 89 parts car rear hubs whwn replacing springs and shocks because one of the 93's were damaged. I have a feeling i may have done a bad thing but a little relief that the 89 doesnt have abs shrug My question is will the vss problem not allow the computer to go to open loop, (open loop is when the car is warm and reads from the sensors right, please correct me if i'm wrong). Tommorow i'm gonna check for vaccum leaks concerning the leaks and take it from there. Thanks Everyone
