clutch fork removal
Phoenix
SHOHOLIC
QC , Canada
The only way is to remove the tranny.
Now the best way to do it is to hold the engine up with supports and drop the subframe.
Racer X
SHO Pilot, Retired
Connecticut
Step 1. Remove fork to shaft bolt (14mm socket)
Step 2. Twist and pull shaft off of fork. Use of a penetrating oil may help (1:1 ATF:Acetone is a favorite)
Mind you, this all has to happen with the transaxle out of the vehicle.
