masho95
got Zex?
I was reading through another post the other day about if you can't shift into reverse after putting the car in neutral with the clutch pedal down for 5 seconds then shifting into reverse without grinding you clutch may not be completely releasing... well mine will grind if I try the above. So the self adjuster on the clutch pedal does nothing if I try to lift the pedal, so here's my question. I reached down there and felt the teeth on the clutch adjuster quadrant and it's all the way to one end of the quadrant, so perhaps that's why it's not adjusting anymore.
As the clutch wears is the cable supposed to be tightened towards the rear of the car or more slack given towards the front of the car?
From what mine seems like there is no more slack being able to be given towards the front of the car in the cable. So looking at the quadrant from the side of the passenger side it would be completely rotated clockwise. The only way there are more teeth is to rotate it counterclockwise and seems like the clutch cable would have to get tighter... Anyone know how this works?
