roswell998
Just thought I'd share how I was able to thoroughly clean the oil and debris from my plug wells for less that $1. This was done before removing the valve cover for 60K. It might sound involved, but it takes longer to explain than it does to do the job.
1. Leave spark plugs tight until the wells are clean.
2. Get a thinwall 3/16" dia brass tube from a hobby shop about 6" long.
3. Put about 1" of the end in a vise and carefully flatten it.
4. Insert the other end into a 1/4" OD vinyl tube and run to a hand pump. I used a Black&Decker JackRabbit which I already had, but they are scarce now and expensive . DON'T use an electric pump that may create a spark!
5. Suck all the oil out of the plug well. The flat section will go beside the plug all the way to the seat allowing nearly every drop to be removed.
6. Pour in about 1 3/4 oz of gasoline which should be just below the valve cover plug well seal. It's best to measure rather than pouring by eye to keep from making a mess.
7. Stir around with the brass tube.
8. Suck all of that out. Do this a couple more times and the plug wells should be free of oil.
9. Let gas evaporate a couple of minutes and then blow plug well out with air. All dust and other debris should be expelled. Mine looked as clean as when new.
It might be overkill, but in my opinion even one speck of sand in the cylinder is not a good thing.
See pictures:
http://www.photoisland.com/servlet/GuestLogin?USERNAME=roswell998
Guest Password: plug
Album: Plug Well
See pictures:
Album: Plug Well
