Check these brakes out!!
SHO2NV
Not low anymore
Angola, Indiana
I believe his nickname on here is DeconBlue. I took this at the Maumee meet this year because it is the sweetest brake set-up I've ever seen! Just thought I'd share it with everyone.
John
Green 94 ATX
Indiana tags: SHO 2NV
"Not much faster than stock...but a whole lot better looking"
my web page: SHO 2NV
SHO2NV
Not low anymore
Angola, Indiana
They had "Cobra" on the calipers and that's really all I know. I didn't get a chance to talk to him about em. Maybe he'll pop in.
John
Green 94 ATX
9
94ShoOff
Guest
He is on here once and a while. Those are sweet! I wonder how much trouble it is to convert them?
Shooff94small
94'ShoMtx, 91'Sho,87'Grand National(modded),97'NinjaZX7R,90'Grand Am Se
Wifes cars: 93'ShoAtx(fresh 60K service, $ ouch), 91'Corvette Conv.
RStalveyARFF
too many shos
Georgetown, MA
it's not that hard. SHODWN knows how to do it. It involved installing the left caliper on the right knuckle and vice versa. They are cobra dual piston calipers.
ryancutler
Somerset, WI
anyone have any idea how much they run??
thanks
Ryan
[email protected]
[1992 Silver MTX]
IRT Performance Clutch, Dynomax Exhaust, Lund Tail light Covers, Coneless, K&N
[In Closet]- NOS #5120, red neons, red wheel lights, blazer techs, side marker lamps
[Next]- Rebuilt 3.2 with Ported & Polished Heads, Raised Compression, Stage II Cams, Adjustable Cam Sprockets, Stage IV IPT Clutch, 3 Angle Valves, Upgraded Valve Springs, IPT Coil Overs, Guages (A/F, Oil Pressure, Temp), IPT LSD, 17x7 Konig Caffeines, Nitto 450's 225-50-17, and PP y-pipe
[1993 Green ATX] -4 SALE-
Coneless, 73mm MAF, K&N, Superchip, DynoMax Pipes w/ [Glasspacks (Click 2 See Video)] -- [Another Video], 68mm TB, Removed A/C Compressor, Filled Body Molding (Gold), White Faced Guages, ACCEL Super Stock Wires, Powdercoated & Polished Intake
WaterRooster
Here
hmmmm on a 93 SHO
96 upgrade....1 Piston brakes....$995
Bear PBR upgrade....2 Piston.....$1205
TCE SHO stoppers....4 Piston.....$1545 + 200 core
So for the Cobras based on the piston to price set up, I would say we are looking just around $1100, now if someone tells me I am right, I am gonna poo a brick
Shawn
93 Emerald Green MTX
CAI,PP Y-pipe, Dynomax Catback, 80mm MAF, LPM, Ebachs and Tokis
rlw001
Reading, PA, USA
Check here: http://www.glen-net.ca/shonutperformance/
They have different brake packages including 96' and Cobra brakes.
I thought about putting together a 96' brake upgrade group buy. Is there any interest.
Bob W
94' ATX, SHOshop Y-Pipe, SHO Shop UDPs, 70mm FPS MAF, SuperChip,
K&N Panel, Coneless, 96' Brake Upgrade, Colgan Bra, PIAA 1552 Driving Lights, Eibachs/Tokicos, 24mmFSB, 26mmRSB, Subframe Connectors, 17x8 TSW Hock Rs, 225/45/17 Bridgestone RE040s, 255lph Walbro Fuel Pump.
AutoXSHO
Glenwood, MD USA
You can see more pics of his brake setup on:
vorlon.cwru.edu/~jpv/SHObrakes/
They are indeed Cobra front brakes, but those rotors cost a lot of money. I can attest to the fact that they haul the car down like, NOW.
John V
95 MTX with mods.
jthomas68
Area 51
That`s nothing,my buddy`s got the Cobra 13" brakes on front AND rear.They leave about 1/4" in the 17" wheels!
Jeremy Thomas
Modified 91+
Pic Of The Week:
DeaconBlue
Cleveland, Ohio
Yeah those are my front brakes.
If you have a '94-95 or a Gen III, it's a bolt-on. If you have a '89-93, then you need to convert to the '94-95 front spindles. I got the Ford factory brakes off a '94-01 Cobra Mustang that was getting a 14" front upgrade. Those are PBR 2-piston aluminum calipers and PBR/factory steel mounting brackets. You can also use the same HD PBR calipers off a 1LE Camaro/Firebird or '89-96 Corvette with 13" HD front brakes or a '01 Bullet Mustang. The 13" rotors are Baer EradiSpeed 2-pcs light weight units; drilled, slotted, directional vein and plated. I used these vs. the stock 13" Cobra rotors because they were 2.9 lbs lighter each. They are expensive, list price is $525 per pair. At the time, Baer didn't have them in the Taurus 5 x 4.25 lug pattern, so I got them in the Cobra 5 x 4.5" pattern and had them machined. They have since added the 13" rotor with the correct Taurus lug pattern to they EradiSpeed product line. I painted the calipers red with VHT brake paint. I run the CarboTech "F" compound pads front & rear.
I have just ordered all the parts to do a custom rear brake upgrade using the 11.6" front rotors and the wider '89-92 rear calipers. I will probably use a PowerStop drilled and slotted rotors to match the look of the front's, because Baer doesn't offer and EradiSpeed replacement rotor in the 11.6" size for the '96 SHO. BTW, you need to run 17" rims to clear these 13" front brakes.
And yes they make a world of difference (even more so than the 11.6" front upgrade did) along with the SS brake lines and modified rear load proportioning valve.
Just ask AutoXSHO, he's drive my car.
95 MTX
with a few mods
DeaconBlue
Cleveland, Ohio
BTW, you can order this same front setup from Baer p/n F6FT2520013, if you don't want to fine all the parts seperately, for $925. Or you can upgrade the 13" standard Baer claw kit for the '94-95 SHO p/n F4FT-10150-5HN at $625 with the EradiSpeed rotor option p/n ORAH-12152-001 for an additional $270.
Granted, cheap it's not, but I want/need all the stopping power I can buy.
95 MTX
with a few mods
DeaconBlue
Cleveland, Ohio
Check the other reply. Yes the 2-piston PBR caliper's mounting bracket can be modified to allow them to be used with the 11.6" front brakes and it saves about 4.0 lbs per side compared to the factory stock iron '94-95 caliper, mounting bracket and pads.
95 MTX
with a few mods
94shoboy
south shore, mass, usa
deacon can you keep us updated on the custom rear upgrade? i want bigger brakes in the back, the stockers look ******** with the 17" wheels. is there a site where i can get your brake setup? i was going to go with the SS 13" baer setup, but i want the 2 piece rotors. thank you
DeaconBlue
Cleveland, Ohio
Several people have done the rear upgrade. The first person did his back in Nov.'99 Most people have only gone with the 11.6" front rotor, a few have done the 13" Cobra front rotor. If you run 17" open design 5-7 spoked wheels, it really helps the look as well as the overall braking performance.
The key is to use the '89-92 rear calipers that will work with the 1.1" thick vented front rotors. You then have to fabricate up adapter blocks that move the caliper and mounting bracket further away from the axle center line, similar to what AEM does with their Honda big brake kits. You also need hubcentric ring adapters because the rear hub has a smaller diameter than the front hub.
95 MTX
with a few mods
SnoSho
Circle Pines, MN, USA
Just want to make sure I'm understanding deconblue and jt68 the Cobra fronts have also been used on the rear of the SHO?
Tim M.
