Check engine Light
Bizzy
1994MTX:
Does the CE light have to be illuminated to have codes on the EEC.
No, the CE light could have come on for even a moment and then gone off. You would have a code stored for when it was on. Some problems do correct themselves.
1994MTX
Sturgis, MI
i've just started having problems with the car in the last 3-4 days, and i've never had a check engine light come on. The only advice i've gotten is have the EEC read, but it would be a waste of money if i've never seen the CE lit right?
anthony
new york
Make sure that ce bulb works .
some places decide to disconect the CE light
to make it stop lighting . (speaking with expierience)
Bizzy
1994MTX:
Check out www.shotimes.com They explain how to read the codes yourself. There could be a code stored in there and it may or may not make a difference. Best bet is to learn to do it yourself or find someone here who lives close to you who has a reader.
Bizzy
1994MTX:
???????????? paper clip?
i'm lost
Check out shotimes...they explain how to do it. It's really very easy.
1994MTX
Sturgis, MI
to run the EEC codes using the procedure from shotimes, how exactly do i know what numbers the codes are, i see what needds to be hooked up (jumped) but how do read the codes from the CE light?
Huntervf
Bored now
Back in Michigan ... again.
Hey, I see you're in Sturgis...I'm only about an hour north of you, in Portage. I'm pretty busy, but if you have a chance to drive up this way I'd be happy to take a look at your SHO for you thumbs_u
Bizzy
Huntervf:
Do it...Chris knows his *******.
1994MTX
Sturgis, MI
I'm sure it'd be worth the trip up to portage, the problem is it isn't running, making that a little difficult.lol
but i'll look you up when its runnin
