check engine light
SHOman19
Des Moines, Iowa
Replaced both O2 sensors and mass airflow sensor on my 1994 mtx. What is causing my check engine light to come on intermittently??
SHOTIME
Giver of life
Boston Ma.
Pull the codes.. It tells you what the problem is.
Eric
mailto:[email protected][email protected]</A>
My Web Space
New England SHO Specialists
ACV1081
Member #187
IA US
About a $.02 cost to you to pull your own codes is explained in detail on the www.shotimes.com website. It envolves a jumper wire & watching the CE light blink inside you car. There is also a table there that will correlate to the number of blinks & tell you what is wrong. Very simple & beats spending $40 to get your car on a computer @ a mechanic. Check it out.
The fleet: 1012264997459 123
~Adam Varney~ mailto:[email protected][email protected]</A>
1993 RED ATX(3 replacements) W/shiftkit, 135,000 miles(Fresh 60/100K THANKS SDPATT!), 17" Konig Reigns, 245/45/17 Goodyear F1 Gs(Summer), 225/55/16 Blizzaks WS-15's on slicers for winter duty, 26mm ASB w/poly bushings, Tweaked stock airbox with K&N panel filter, D4U1 computer, blazertech fogs, & performance friction brake pads, SHOSHOP Stut tower braces(front & rear). GTECH times 0-60 in 6.92 1/4 15.3 @ 98.4.
Not yet installed: poly bushings... Upcoming: Well you could just say I am on hold since I bought a gen.1 now.
New to the lineup: 1991 White MTX- 122,000 miles, recent 60K & clutch, CINCYSHO cowl hood, K&N filter, rod shifter, dynomax catback, SHOSHOP y-pipe, & white slicers w/ 225/50R16 Dunlop SP Sport 8000 tires(Being sold & replaced :p . Too bad she'll be sitting till spring cause I'm not driving it in the salt & sand. Website with pics from previous owner: http://www.homestead.com/SHOIOWA/SHO_Spring_2001.html
