Check engine light came on
Bswizz
So my check engine light came on. I took it to auto zone to run a check on the computer & this code pops up P0018
Crankshaft position sensor. The part is fairly in expensive. So the question is has anyone installed one of these on the SHO? If so any tips on where it’s located at & it’s removal? Is there a bigger concern here?
I have gotten under it to see if I can see a sensor close to the crank but I don’t see anything. Any tips would be appreciated.
TanK203
Connecticut, USA
I had the same code, and apparently Ford saw an O2 sensor code that I never saw. Turned out to be an issue with a wire harness. Apparently some of the wires had melted together and were shorting out. I say this in case replacement of the sensor does not fix your issue.
Sent from my Pixel 2 using Tapatalk
Not knowing what year your SHO is, here is a diagram of the location of the CKP sensor 6C315 on a 2014:
2014 SHO Crank Position Sensor Location
f019508304.svg
100216
100215
100214
Sensor - Crankshaft Position - Cps
Part #: DY1351 (6C315)
Motorcraft 2
Crankshaft/Pistons and Bearings
Usage: 02/06/2012 - 09/30/2019, Taurus, 3.5L DOHC T/C V6 Gas
Basic instructions:
Removal and Installation
All vehicles
  1. With the vehicle in NEUTRAL, position it on a hoist. For additional information, refer to Section 100-02 .
3.5L GTDI vehicles
  1. Remove the LH turbocharger. For additional information, refer to Section 303-04D .
All vehicles
    • To install, tighten to 10 Nm (89 lb-in).
  1. NOTICE: Remove the bolt and the CKP sensor from the bell housing before disconnecting the electrical connector to prevent the CKP sensor from falling in the bell housing.
    NOTE: Follow the unique instructions or graphic for this step in installation.
Installation
All vehicles
  1. To install, reverse the removal procedure.
    • 2. Tighten to 10 Nm (89 lb-in).
3.5L GTDI
  1. Using the scan tool, perform the Misfire Monitor Neutral Profile Correction procedure, following the on-screen instructions.
Bswizz
I couldn’t access any of the links. Removal of the turbo LH? Is that the one closest to the cabin?
Correct that is the firewall/cabin side of the engine bay. References are typically based on looking straight at the belts with the engine banks on either side. So LH would be the bank on the left, RH the bank on the right.
The links only work if you have the FSM online, sorry.
Might be an easier way to do it? People always find a workaround to the factory way of doing things, so ... :)
shaker281
USA
I wonder how critical this step is?
"3.5L GTDI
  1. Using the scan tool, perform the Misfire Monitor Neutral Profile Correction procedure, following the on-screen instructions."
I assume this is done to set a baseline for the new CKS, and is thus a necessary step. Might be possible with Forscan, but IDK.
