Changing waterpump...
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
LiLGhettoSmurf said:
What else should be changed while its all taken apart?
Water pump (as stated), Timing Belt, Cam Seals (3), Crank Seal (Front Main Seal), Crank Sensor, Cam Sensor (ONLY replace if bad), and Accessory Belts. Also inspect the condition of your lower rad hose, and if need be replace it because it will be coming off anyhow. Good luck!
PS: If you don't know already, this site has an excellent write up on completing the procedures stated above. . . http://www.shophoenixproject.com/lower60k/lower60k.htm
