Castrol ATF Type F tranny fluid...
DavidT
TN
Is it a good product to put into my 90?
Speedy_91_SHO
Toledo, OH
Use the search feature. It will give you better results thumbs_u and not make members mad :mad: at you for having to respond to the same kinds of posts over and over again. I recently wondered the same about my 91+. I searched and found most people like either Redline or GM Synchromesh. I am going to go with the GM Synchromesh when I get a chance.
DavidT
TN
I have read many posts on the subject... (did not use the "search" per se...) but I haven't seen anyone mention Castrol Type F.
DavidT
TN
I know this topic has been "abused", but... does a gen.1 have the option of using Type F OR Mercon III?
NotSoSlowSHO
Gas is $$ WALK!
Moscow, IDASHO!
dkautumna:
I believe the issues are with model year '89 only...
I have an '89, but the trans was rebuilt so it's all good. :D
X
X-15 SHO
Guest
I'm running Castrol ATX Type F in my tranny (89) and noticed nothing, but I'm in need of new blocking rings and some synchros. :D I'll drop it soon and replace them and put my new Castrol back in. Honestly thought since I put my clutch in and new Castrol fluid, it seems as if my 3,4, and 5 gears are harder to engage (rings), but my 1-2 assembly (synchros & rings) are bad and seem the same and 1st is acting up more then before too. Will see the results though after my rings are installed and 1-2 synchro assembly.
<small>[ February 23, 2003, 03:23 AM: Message edited by: X-15 SHO ]</small>
hosbaldosho
