Markus
I cannot separate the right hand front control arm from the strut rod. I can't even get the rod to turn within the LCA. Has anyone run into this before? Please help!!!!!
It is also very therapeutic! gas..spark..Burn! n8rsk8r said:I had mine froze up pretty good, are you changing the bushings? If so, HA HA....GET A TORCH!!! That is what I did, I simply burnt the mothers out of there! :evil_gri:It is also very therapeutic! gas..spark..Burn!
91taurisho said:pulled my LCA off the car along with the strut rod. I then hammered the lower control arm with a very large buckshot hammer. it eventually slif off the strut rod, it just took a while.
Markus said:As a matter of fact I am changing the bushings. I melted the strut rod bushings this morning when heating the nuts on the front of the strut rods. I had considered a fire wrench to free the strut rod from the LCA, and I now know I'm not the only nutcase in SHO land. Tomorrow it's LCA bushing's trial by fire.
Oh and throw an insult every once in a while too!
htheduck said:Removal of that was a beast! Yes, propane torch.
