Irish Pride, I'll try to do today what you suggest. Can I just reach behind the engine and take the plug out or do I have to move stuff before I can reach it??? I wish I was a more confident mechanic.
Zoomlater, thanks for the great pictures. I'm thinking that the s-L1600 assembly fits on the base shown in the 6xyZZC5Q. picture. and the cam seal o-ring fits into the circular trough in that picture. Is that right?? And there was 2 gaskets in the sensor seat.
Also, could you all help me understand this oil leak problem. How does the oil flow into the sensor and where does it come from???
I'm asking because I've had this problem before, about 14 years ago. I know this because I have this dim memory of having a very similiar experience and went back and checked my records. Indeed, before I understood that the cam shaft position sensor could be contaminated with oil, I had the same symptoms I'm having now - bucking (it was more violent back then according to my records), a wild tach sometimes, rough running, and hard to start and keep running sometimes.
I had the cam shaft sensor replaced after running diagnostics and getting the 19c ec. but had the same symptoms. I sent a note to the former owners of ShoSource and they told me to look for oil in the sensor housing and there it was. I checked the 1st sensor taken out and it had oil in it.
I had had the first sensor taken out without knowing to look for the oil and put a new one in that apparently immediately got contaminated. The person at ShoSource didn't say anything about replacing the cam seal if I found oil and the mechanic acted like he knew what to do and when the car came out of the shop, it was running. So I went with that outcome when asking a few more questions would have help me understand what the mechanic had done.
The sensor had oil in it when I had it taken out this time. Not having the cam seal o-ring or even knowing about it, the mechanic put the new sensor in with the same symptoms occurring again. And at that, I had let what happened 14 years ago happen again,
The car has been running very well until this latest event although it is using oil. I've planned to have a valve seals/covers job done soon. I'm wondering if the oil leaking through the valve seals could be the source of contamination or is the o-ring the main suspect. Also, is replacing the cam seal a musch bigger job that just doing the sensor. It doeent look to bad, but what do I know? I would like to put the sensor on myself.
Iknow this has been long winded, Thanks very much for you alls time.
Craig in Kentucky
