Can I damage or otherwise royally screw up anything by bleeding the brakes with the engine running? Someone on the shotimes mailing list said his snapon scanner has instructions for bleeding the abs system. The instructions say to run the engine and open one bleeder screw then bleed normally. This is supposed to cycle the abs pump somehow. I don't know if it will work but I want to try it and I don't want to mess anything up.
Thanks
Thanks
