Busted Rear Way links
Egg
Who?
Plymouth, Michigan
Busted Rear Sway links
Was under my car looking for a massive exhaust leak and found that my rear sway bar is not connected at all you can still see the poles where the bishings used to be but they are long gone, what do i need to replace to get everything up to *****
Ishodu
You need a set of rear sway bar end links. They install on the bar to the strut housing.
hawkeye18
Sorta cares
Norfolk, VA
Just go to russ's site at http://home.earthlink.net/~rcm_automotive/
and order up a set. They're pretty cheap. He also sells 'em on ebay if you prefer that. make sure you do both sides at once or you will *never* be able to twist the bar enough to get the other side in. Also, make sure you remember to put the big washer between the bottom set of bushings and the bottom bolt. They make a god-awful noise if you don't. Ask me how I know that :).
Egg
Who?
Plymouth, Michigan
You know i really dont notice anything to severe without the rear sway bar, Its probably been busted since I bought the car last year
jsho
Wisconsin
A note to anyone: Don't buy the links from napa, they break very easily. :mad: Of coarse I may have torqued them a little to much. :rolleyes:
DHMag
Free At Last
InCahoots, Texas
its a common mistake on endlink bushings to overtighten them. you only need to tighten the nut until the bushings begin to compress. if you crank the nut down til it stops, youre defeating your own purpose.
personally, i dont like endlinks that use a long bolt and metal sleeve. ive had too many negative experiences with that style. for the same price paid for aftermarket links, i bought mine from Ford and they came with TPR bushings.
Minnesho
i was wrong
MinneSHOta
SHO Continental said:
how does it handle like that?
when mine were broken it reminded me of a small boat in the middle of a monsoon. well, it wasnt that extreme but its deffinitly noticable!
TankII
Bolton, CT
http://photos.yahoo.com/[email protected]
Look over this kit that I put together using Hellwig and PST parts. MUCH better than anything else I've tried over the years.
<edit>
Oh, and they are 3/8", not 5/16" bolts. When you are done, the rear is smoother riding because the bar reacts immediately, but is MUCH stiffer (mine squeels the rear tires in tight corners)
<end edit>
TankII
