So, I got unlucky and lucky the other day- unlucky in the sense that someone's truck kicked a piece of debris into my path, lucky in the sense that the bumper cover and the tire took the brunt of the damage. There is a small tear in the cover and the very tip/end of the cover tore at the hole where the connecter secures it to the fender. The tire blew out completely, but I have road hazard coverage on it. Photos to follow.
Questions:
1. What is the best way to secure the corner? I don't want it to be constantly popping loose and sticking out. I can replace the connector, but the "loop" it passes through is torn.
2. Any advice on how to minimise the appearance of damage to the cover? If you look at the pictures below, they were taken with the flash on, and most of the scuffs are not deep, and should buff out. It won't be perfect, but it's honestly not that bad. The worst part is the one small crack/tear, which actually sticks out a bit from the cover. For scale, the scuff/crack/tear can be covered by a dime.
3. There are two possible orientations for the autopark sensors, connection on the top, or connection on the bottom. Does it matter which way they are installed?
Thanks!
Questions:
Thanks!
