Brakes
SLOWgod
Weeeeeeeeee
Has anyone ever put drilled or slotted brakes on these car before ?
also where could I buy a set at.
bpd1151
Lurking Around
SHOcago 'Burbs
Ron Porter, current SHO Club El Presidente would highly recommend against such frivolity.
Last I recall, he was/is a BIG FAN of solid rotors and I believe the brand name he favored were/are "Carbotechs".
Hopefully he'll see this, and add his own two cents as he sees fit.
Zpak
Es Aich Oh!
The region, Indiana
I have Powerstop drilled and slotted. I got them from Summit. Stops like a beast. From research and personal experience I think they are probably the best middle ground between daily driving and performance use for the money. With the evolution Z-23 pads my only complaint is that they are a bit noisy after about 5K miles and they don’t last as long as OEM. But, that’s expected with their enhanced performance.
Zpak
Es Aich Oh!
The region, Indiana
coming from the guy with the fanciest brake setup I’ve ever seen on a Taurus. Hahaha ;)
bpd1151
Lurking Around
SHOcago 'Burbs
I know, right!?!?!?!
But I haven't always followed our illustrious leader's advice mind you.
As evidenced by my own choice to rock the big brake set up from Wilwood on my heavily modified GEN4.
Zpak
Es Aich Oh!
The region, Indiana
It was funny, shortly after I put the Powerstop’s on my wife drove my car. After almost putting us both through the windshield she said, what’s wrong with you!? Nobody’s car stops like this!!!
gamefanatic
Barstow, CA
I once had the drilled slotted rotors on my SLO. Driving on a slight decline and put about 50% on the brakes all at once and didn't slow down a bit, but made a whole lotta noise... Moral of the story, don't stop at upgrading the brakes if you want to stop now...
stephen newberg
Ladysmith, BC, Canada
The drilling and slotting is now what causes sudden huge brake onset, but rather how the calibers are set up to respond. D&S simply gives better cooling by increasing the surface area of the disk and provides an easy place for residue to move off the disk quickly (plus, of course, a slight decrease in weight). If you are not using the breaks a lot and hard, overheating and residue on the disks is likely not going to be a problem, so moving to D&S is pretty much a wasted effort.
pax, smn
GEN 3 SHO FAN
Canada
pax, smn
I don't know if someone saw them in US but I put on mine ATE brand with small elliptical grooves on them to evacuate water and dust. I must admit that in heavy water, you don't have to pump the brake to brake (security upgrade ?). I have them since 5 years now and they still strong (no rust, good tickness). They were sold as high quality here (Canadian Tire store) some year ago. Sadly, they are no more offered there now.
Also their look fit with the elliptical look of the Gen 3. :)
412ZOYIK yL
Also, if you are searching braking power, you can retreive the valve bias of the rear brakes. Which is could be considerated as a maintenance upgrade because this valve become cloggled over time and retrieve progressively brake power from the rear.
gamefanatic
Barstow, CA
I should also add that many shops wont turn slotted / drilled rotors simply because of the problems related to scrapping their bits across the open portions and the damage that can occur to both their equipment as well as the rotor.
Might not be a big deal, but I have rarely had a "need" to replace my solid rotors vs just getting them turned due to uneven pad build up.
PaulTAutoX
San Ramon, CA
My $.02 is that drilled is for race cars where you're willing to do the regular inspections for cracking starting at the drill holes. It's also much harder on the pad life due to the edges. Yes, they are lighter, but the loss of thermal mass means that the rotor may get to hotter peak temps which somewhat offsets the increase in cooling.
Slotting has similar effects on pad life though it varies with the aggressiveness of the pattern. Generally not as likely to cause cracking, and said to be better for the first wet brake application, though I have no personal experience. I have friends who tried slotted rotors for their track day cars and found that they ate pads quicker than non-slotted.
I bought cryogenically (frozen) treated rotors because they have been shown to have better life, and skipped the slotting and drilling. I think this last set was Centric brand, don't have the receipt handy. They are available at Tire Rack. I use Carbotech Bobcat (I think the p/n is 1521?) compound because I don't track this car, and pads never get hot enough at autocross to fade, and they are consistent first stop to later ones unlike the Hawks I had which had to get a least a little heat to grab.
gamefanatic
Barstow, CA
I second the issue with cracking. I had the Baer Rotors and they cracked within a few months of use. Never went back to them mostly due to lack of stock and gave up waiting after a month on back order.
I generally just use the top flavor of Duralast Gold pads. Lifetime warranty and properly bedded no issues. I have Yellow Stuff pads for my Cobra Calipers I haven't used yet.
stephen newberg
My Porsche 997.2 C4S came with drilled rotors, and it is getting toward 10 years old now with no indications of cracking. And I do, on occasion, brake very hard as most of my really fast driving occurs on rural back roads where deer and livestock tend to show up rather unexpectedly, as, on occasion when trying new routes, do very hard and not well apexed curves. Of course, those rotors likely cost a mint, too.
pax, smn
99sho-time
I don't care for the vibration they cause. our cars don't need anything making it harder on parts. so i got rid of my power stops.
Michael W House
Colorado
The single best thing I did for my '99 was installing StopTech drilled and slotted rotors and Hawk HP pads. The difference in stopping power and pedal feel is actually hard to explain because it's so dramatic! I've used this rotor and pad combination on a number of different vehicles, have recommended it to friends looking to upgrade and all have been impressed and satisfied. I had ATI rotors on a Gen3 Jetta GLX and didn't like the pulsating hum under hard braking, though they worked well. These rotors don't make much noise, are nicely progressive and bite really, really hard the deeper you get into the pedal. I've got many thousands of miles on them on several different vehicles and have never regretted it. One thing though! You must do all four wheels! I did one, then the other and there is a big, big improvement with a set on the rear!
Qshiplvr
P Springs
So the disc size is still stock for Taurus and you upgraded to Cobra Calipers? I was wanting bigger brakes due to undersized nature of our stock discs, but struggled with the fact that if I upgraded to Cobra brake discs, they wouldn't fit stock SHO rim size, and I'd have to spring for 4 x new upsized rims and 4 x tires. Also, disadvantage when your flat is on front wheel, as the spare won't fit over Cobra discs (not sure what sized spares Cobras used when they got flat), so my buddy had to swap the good rear time on the front, before changing the flat out with limited use donut.
gamefanatic
Barstow, CA
No the Cobra caliper fits over a 13" rotor drilled for our lug patern.
