Eric VerValin
PiMPSKiLLET
Ok.. well sometime this spring, I'm going to need to address my rocker panel rust issue. Unless I find a cheap black Taurus / SHO, from somewhere down south, that has a blown motor or something. Anyway.. I'm assuming rocker panels cannot be bought, so I'll have to either cut some good ones out of another car... (seems impossible to find) or bend some sheet metal to fit.
I'm sure someone has done this somewhere on here before, and I'd like a little help or direction to get stuff ready for this spring. The work dosent have to be ''perfect'' being the welds would be inside the door area, and under the car. But I dont want it to look too terrible either. I would assume it wouldn't be too bad to grind the welds down a bit inside the door to make it look a little better, or maybe install some of those aluminum door sills on top of the welds to hide it maybe?
Anyway, just looking for ideas on how others have fixed their rockers. And also when adding the ground effects back to the new metal, should I use sheet metal screws like the factory did, or would it be a better idea to actually tap a few good holes and run some machine hex head screws in there? 1/4 20 's ?
