Biggest rotors
NJSHO
Clean Your Shorts!
NJ
As long as your not stock for long as your profile states, get some 17's and you can run 13" rotors. 2 piece is nice to reduce weight. The larger the rotor the more weight you have to turn the less acceleration and suspension responsiveness you have. That extends to wheels and tires.
jeanrw2000
Lechon Asado!
Brawley, CA
Did somebody say 13"s?:nut:
you need bigger tires though:dribble:
jedhead
westminster,ca
12.5" Rotors 1lbs more than stock. Calipers weigh less
Knunkles weigh 6lbs less
17X8 OZ Wheels and 235/45-17 tires 41lbs
You can contact Todd at TCE performance. He may be able to make some 14" or 14.5" setups.
You may be able to get a Baer Racing sport set up with 14" rotors and make new caliper mounts too.
All these ideas are $$$$
Bob
jeanrw2000
Lechon Asado!
Brawley, CA
Bob
Those are sweet too, :thumb: Uhh i like those very much also...:dribble: :dribble:
Jean.
yamahaSHO
E85 whore
Arkansas
Yes, 2-piece rotors are lighter, but the critical weight is still on the outer diameter of the rotor, so it's not a big difference in the weight vs acceleration/stopping respect. The aluminum will bleed away heat better though.
jedhead
westminster,ca
I also have less unsprung wieght that help with the ability for the suspension to respond. Also I have smaller rotors than the 13" rotors that are commonly used.
Bob
Sh03d
Sho Ed
Fairfax VA
12.5 consists of
Mustang GT PBR calipers?
Different Caliper bracket?
12.5 rotor?
94-95 Knuckles?
Shoaz
Studly dood
Scottsdale, AZ
Sh03d said:
12.5 consists of
12.5 rotor?
94-95 Knuckles?
Baer 12.5" kit. Modified pre-94 knuckles, HD PBR calipers. Todd (TCE) has the pieces for a two-piece rotor, which is what jedhead is showing.
Nice kit. That's what I've had for a long time; it's currently on the Pumpkin.
