best rear control arms
rktmn
Well-Known Member
miami
I called BMR last month asking for the sleeves, and they told me that they did not have them, nor were they available.
I will take apart the rea end this week end and see what I need to do.
Thanks guys.
Jose
RAYJAY
WHO ME ?
UNION DALE PA
your asking for the wrong item they don't make sleeves they have a 12mm bushing to replace the 14 mm bushing that come with the the BMR arms
Jeff
S
shoebilly
Guest
Hack said:
Jose, the TCE arms were steel but they are no longer availible. Doug at FPS sells purpose built aluminum pieces for $399. About the same as you would end up spending on the BMR units.
I hope Doug does not mind me "hotlinking" that.
FWIW, I have seen a GM control arm bend on an SHO.
A compatable steel replacment can be found at Coleman Racing. They have a large mailorder site. I believe the 20 1/2in tube is the size I used although mine are alum. hex tube. I use the curb/rumble and have never bent a thing. I suggest spending the difference and get the high quality 5/8 x1/2 Id rod end. www.colemanracing.com
lunchbox0029
Fort Worth
What is the part #
jedhead
westminster,ca
We will have them for sale when we get "legal" paperwork done. Here is a picture.
Some people have made their own.
Bob
SHOBros Garage
S
shoebilly
Guest
The part I used was a aluminum hex tie rod #19105 20"- 5/8' female rt.& lf. handed thread & used 5/8 x1/2ID male rod end. The knuckle needs to be drilled out to 1/2'. I did mention this part is availiable in steel. I an have a old catalog and the part is not listed. I would look in steering parts, tie rods, trailing arms & strut tubes. This is a good outfit to deal with. Check out pt.# rp-129-20 and 127-120 I don't have current prices but sould be in the $10 - $15 neigborhood ea.
ManySHOs
South Jersey
I haven't read this entire thread but if there is enough interest I will resume my efforts for a BMR group buy. Once I start talks, I'll ask Bizzy for permission to start something officially and post it in the appropriate forum.
Ian
ManySHOs
South Jersey
They look nice but they aren't adjustable, are they?
Ian
jedhead
westminster,ca
February. I paid the SHO Shop $99 for the one pictured. Once we contact the supplier we hope to be able to lower the price with a group buy.
Bob
rktmn
Well-Known Member
miami
I ended up purchasing the control arms from BMR and the H brace from Josh \ Shonut. I considered making my own, but the necessary time involved to make either product would have not been cost effectve for me, plus, I did not feel that I could have improved much on the designs.
Jose
S
shoebilly
Guest
Ian
Of course they are, the purpose modifieing the rear links is quicker, easier, ajustments+more ajustability. Using sphereical rod ends eliminates all 8 rubber bushings on the links.
ManySHOs
South Jersey
I think that I misread your post and misunderstood the picture. Gotcha now! :thumb:
Ian
S
shoebilly
Guest
This outfit www.colemanracing.com is a manufacturer of racing parts out of Michigan and anyone that wants these links will have to buy the parts piece by piece out of the catalog and use a little yankee inginuity to figure out whats needed to assemble a safe part. There are other oufits around regionally in my area so I'm sure there are others that might be more convenant for those in other regions. I can vouch for this place being quick on orders & technical help, but remember they are making race car parts not SHO parts. Ordering a catalog is free and there are lots of aftermarket brake components that one might find interesting.
ManySHOs
South Jersey
shoebilly said:
This outfit www.colmanracing.com is a manufacturer of racing parts out of Michigan and anyone that wants these links will have to buy the parts piece by piece out of the catalog and use a little yankee inginuity to figure out whats needed to assemble a safe part. There are other oufits around regionally in my area so I'm sure there are others that might be more convenant for those in other regions. I can vouch for this place being quick on orders & technical help, but remember they are making race car parts not SHO parts. Ordering a catalog is free and there are lots of aftermarket brake components that one might find interesting.
That's www.colemanracing.com with an "e", right? The first link didn't work. I've been to their site before; I was going to order some brake parts for my TCE/setup. I'm going to go through Todd now that he offers a 1.1 specific upgrade with FSL calipers now. Good info on the control arms though; thanks!
FWIW, I think I want to use something with poly or rubber bushings instead of spherical bearings.
Ian
