stangracr67
Couple questions. Can anyone tell me how far the input shaft sticks out of the bellhousing on a 5 speed? Also, can somebody tell me the measurements from the center of the input shaft to the bellhousing bolt holes?
got a clutch with the trans. It's an 11". dont think it would fit on the sho flywheel. Also I am hoping to use the mustang starter so I need the right flywheel to make it all work.
Dont really want to go the t5 route because I dont think it will support the power and abuse.
T5's have been taking abuse in mustangs a long time before the SHO came around. People in my mustang group are putting down 400+ ft lbs on a stock t5. If you think that wont do it they have PLENTY of upgrades for a t5 to make them very durable. Also there is already a adapter plate available for a t5 swap.
edit - Im just guessing here but i think the money you save not using a T5 based trans will be blown very quickly getting all the other parts to fit. But if that's what you want to do more power to you.
I mean no offense by this but it sounds like you don't have anything but a mustang tranny and clutch. I would get a SHO motor and MTX first. Spend some time making your own measurements and fitments, if you really want to tackle a project like this it will NEVER be as easy as you think. Ask the other few on here who have done it. Good luck.
So is the input shaft on a SHO 5 speed even with the bellhousing? Inside the bellhousing? Can someone throw a tape measure on it?
