BBB's?
97SHOgt
Cincinnati, OH
A cam weld won't be expensive for me. My last weld was $30. I did everything but the actual welding of the cams.
Were you in the library today and I walked past and probably was sure it was you so kept walking, because I'm cool like that? Around 9am?
97SHOgt
Cincinnati, OH
Easier to just take the butter flies out and get a tune.
If I did remove the butterflies and get this tune you speak of, will there be noticeable gains. Won't I lose that wonderful sounds of them opening up? Will it hurt my MPG?
chrome_rust
They Dont Float
Columbus Grove, OH
yes the sound will be gone, i wired mine open (they work, was testing something) and i think the tone sounds better now, it is the same after 3400, but getting there sounds better.
Your MPG is 100% dictated by your right foot.:woohoo:
And that wonderful sound is Ford's way of bamboosoling you into thinking the secondaries actually do something.
97SHOgt
Cincinnati, OH
Gotcha. Those tricky SOB's... Will I need a tune if I wired them open? Did you get my PM?
A tune will allow you to take advantage of the wired open 'flies. But it is not necessary.
E1 v2
crash tested
holiday inn
The LIM ports are matched to the heads, so if you want increased flow you need to increase the diameter of both.
+1
BBB's, UNLESS attached to a whole bunch of OTHER porting upgrades, CAN'T do anything, due to other various flow restrictions throughout the intake.
Any one who thinks BBBs will help help the V8 motor is not aware of the programming Ford uses on the V8 below 3400 rpm.
bill6639
Pennsylvania
what do you mean?
can u go into more detail as to why it wont help bc how the motor is tuned
id kinda like to know if its worth while to do if it is ill do it in time but if it isnt worth while id rather not worry about it
