Vroom
Un-Moderator
Before I go any further, here's what it looked like before today:
I worked on the battery in the trunk today. I am VERY pleased with the results now. Allow me to explain what I did differently.
I decided to scoot the battery box away from the corner a bit so that it was resting between that bunker on the side and the spare tire compartment. I was able to screw the strap holders down on flat trunk floor and was also able to screw the two L-Bolts through the flat floor as well. As a bonus, the battery box is now covering up the hole where the duct tape was, and I was able to use that hole to run the straps through the carpet.
Here you can see what it's like sealed. You can see one L-Bolt coming up from under the car.
Here's a shot from under my right muffler. You can see towards the left there's a pink washer and a wing nut; if you go directly right from there, you can barely make out the second L-Bolt washer and nut.
Here's the battery hold down that I purchased to go with the L-Bolts. I had to cut out a section in each to allow the box lid to snap into place.
Here is one of the two little vents on the cover of the box. I didn't notice these before when I was considering venting the box with a tube; now I don't think that will be necessary.
Opinions and comments are welcome.
